does the evo III exhaust manifold fit?
The flange to the head needs to be clearanced to fit by the motor mount. Other than that it is a stock replacement. Nothing changes position.
I used a 2G manifold gasket. If I remember correctly the holes in the gasket are significantly bigger than even the Evo III manifold runners, so the fitment is not a problem.
Actually the flange should be ok on the 1g. My friend just swapped his in. When I order my SBR cast mani it needed a little metal taken off to fit. This is the 1g SBR mani im not sure if the fixed the new one that came out.
sillyme said:
does it fit perfectly on my 1g eclipse GSX with a evo III turbo? any change to the position of the downpipe? what manifold gasket should i use? thanks
It did on mine. I have an ported evo 3 mani. It's a direct bolt on
I had to use an angle grinder to cut the tip of the flange furthest to the right off in order for mine to fit - not really a big deal IMO though!
