2G W5M33 gearset in F5M33
aapje
Mar 28, 2006
Blaat,
My car is kind of a frankenstein package. It's a '95 fwd mirage, I'm running a F5M33 gearbox, that I imported from the states a long time ago (I'm in Europe).
At the moment my gearbox has seen the best of it's days. I probably needs a rebuild. I'm thinking about replacing it with a W5M33 from an EVO1/2/3. (weld the viscous coupling).
But I've read that the flywheel and starter motor would have to replaced as well. (got a aluminum fidanza wheel). I was wondering if I can swap over the entire gear set from a W5M33 (evo box) to my F5M33
I have a 2g case and am using evo3 gears :) I had my trans built by Terhuneraceworks.com (Brian), so I'm not entirely sure what needs to be done. But seems you can if you ask me.
