Virtual Engine Tour? Valve cover? Cam Angle Sensor?
Xploitn
174
Dec 19, 2011
Denver, Colorado
Is there a virtual engine tour link that still works? All the ones that I've searched for are down or broken.
What is this line?
should I get a new valve cover that is already powdercoated? Or should I take mine to get media blasted and powdercoated locally? Will the lettering come out that perfect, silvery, media blasted aluminum color? (This is not a daily driver)
Finally, am I missing my Cam Angle Sensor?
Thanks for all your help, I'm still learning :)
The big line you are pointing to is the AC line to the condensor. You do have a CAS, the 95-96 is located under the intake cam gear. The 97-99 have their CAS where the black plug is that you pictured. For your valve cover you have a ton of options. You can paint,polish,powdercoat or shave it.
I believe that line is an A/C line if i'm not mistaken. As for the CAS I think some models of the 4g63 had them in that location, but if i'm not mistaken, not all of them were? your may be on the other side of the engine by your timing belt.
The 95-96 CAS is here:
97-99 is here, this is my stock 97:
It normally runs to the A/C compressor that mounts to the back of the block just above the axle. If one end of the line is already disconnected, you can disconnect the other end.
I was just reading other threads and saw where you posted a pic of someone pulling their engine and showing the location of the A/C compressor.
http://www.dsmtuners.com/forums/newbie-forum/426439-removing-c-condenser-lines.html
Thanks again
The A/C compressor has its own belt right? (I'm 90% sure) Is the third upper pulley on the A/C belt just for clearance/positioning?
    • george bromwell
    • pma1123
    • Sdcryan1
