98gstJames
- 246
- 47
- May 25, 2022
WInchester,
Virginia
This car man… these things make me lose hope. Anyways, so I’ve been fighting my idle and I went to test it out today and started driving and made it about 30 feet when all of a sudden I heard what sounded like my cam gear cover rubbing against the cams, then my car died, the engine is fine and everything’s good on that side, one of the bolts on my trans to the engine came loose so I tightened it back up, issue went away and then I went to just pull my car to park it and I made it like two feet and it did the exact same thing only it kept doing the loud whining until I shut the car off, the same bolt came loose again so I made sure this time it was super tight. The bolt didn’t come loose again but my my engine is sitting there violently shaking, I can feel it shaking the whole car from inside the car and I know it wasn’t doing that before, I have one bolt missing on the back mount to the trans but I didn’t think that would cause this much of a shake…
