very nooby question! help!
1995 gst
188
Mar 22, 2011
boulder, Colorado
I just bough a 92 dsm awd and there are these tubes that connect to what looks to be the throttle, there are 4 tubes and different colored lines. they where dissconnected and had something to plug them up with, what are they and should i put them back in? if so what order do i put it in?
You can leave them all unhooked. They are just emissions hoses.
No you can not, that is false information, or not detailed enough.
On a 91-94 TB, the bottom most nipple, marked "P" draw a vacuum, you can not leave that port open. The rule of thumb is that you loop all 4 vacuum ports, if you choose to remove your emissions. Two pieces of vacuum hose and each end goes to a port.
Yes. What agentorange said. If you leave them just wide open you will create a boost leak which is something nobody wants.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
