Very freaky and scary stutter.
95fwdtsi18psi
803
Jan 6, 2009
West Laffayette, Indiana
I had loaned out my MBC to my friend because I don't drive the Dizzum very often. So I got it back today and after installing it and adjusting it accordingly, I took it out for a quick pull around the deserted circle track of road I live on. After hitting full boost the car suddenly bucked, it felt like I downshifted from 4th to 1st. It bucked so hard it made my seat belt lock up! Then it did just fine, no more bucking or jerking, I did take it very easy on the way home though. I checked everything and nothing is out of place, and my MBC is set to almost the lowest setting! What could it be?
The easy things to check for: make sure its hooked up properly, and counter clockwise takes boost away.
What PSI did you hit?
I know that counter-clockwise is less boost, 5 psi. It wasn't fuel cut if that's what your thinking. It felt like somebody rear ended me. Yes it's hooked up right, I have it run from compressor housing to actuator nipple.
I defiantly installed it right, it is mine I only had it loaned out. Clockwise adds boost on this one, it's an NXS(yes Ebay) But people do really well with this MBC I had it on 14 when I ran my best time. I don't think it's something with the controller itself per say.
Yessir, with a few other mods, and some DOT approved slicks. It doesn't take much to dip into the 14's a good launch and no wheel hop got me that.
It's current, I do have 560 injectors. And all poly bushings and motor mount inserts.
I've never experienced a fuel cut so severe as that in my my 4 years of tuning. Maybe I have developed a massive and I mean MASSIVE leak besides the leaky #3 injector. Does our dsm's experience such a hard core fuel cut as that? I know I have hit it in my camaro tons of times while tuning and it never felt like that.
Oh wow seriously, that's pretty bad compared to other cars I have experienced it in, then again this is the only forced induction I have ever had, thanks. I'll go boost leak test it right now.
I only lent him the tester and 0 hoses. I pulled the ball and spring out and they are flawless, he was only running 22 psi...The thing is rated at 30.
I;'m on my iPod now, so I'll make this short. My system WONT HOLD ANY pressure. It leaks right away and it isn't just a small injector seal, wtf is up...It's getting dark and I have plans tonight so I'm just going to drive the Camaro instead. But all these leaks seriously need to go away. I just fixed my tb and every other leak last week, which was 4 of them....:cry:
I did, I'm pretty sure my intake manifold to head gasket is blown. I heard all the air escaping is coming from underneath of it. I also ran some seafoam figuring that if it was after the throttle body the smoke would show me, well it did. Tons poured out from underneath the intake manifold. I also learned I have TONS of exhaust leaks. I'm really getting tired of all this shit! :cry:
Rip it completely apart and do it 100% right the first time, locking nuts, threadlocker, good gaskets, etc. Then you won't have problems down the road.
Oh trust I never half ass anything on my car. I haven't touched the inatke manifold on this car yet. I have only had it since January. I was wanting to have a better flowing intake anyways, I'll just wait until I can order one.
^0mm is already on the parts list I have made up. I just ordered a re-sealed 60mm from this site last week I'm waiting for it to come in :)
