Valve cover AN fittings
Austin Jedrzejek
109
5
Apr 23, 2015
Cleveland, Ohio
So I want a valve cover with 2 or 3 AN fittings but I cant weld what should I do this is the last piece to my puzzle and once I get my engine in its all I need. please help.
When I did my evo 9 cover, I use a saw and cut off the nipple then drill a hole to an10 then force/screw a copper an10 bolt in it to create threading. After that I had to wash it in gas over and over to get the cuttings out
But unlike a evo valve cover a dsm valve cover can be welded, and I would remove the baffles when you drill the holes to avoid debris getting into your engine.
