vaccume delete
91'AWDFUN
88
May 15, 2009
La Porte, Indiana
I am doing a vac. delete and am wondering If I remove the purge control solenoid, fuel pressure solenoid, and the EGR solenoid. I am running a JMF Intake. Also can i get rid of the canister on the passenger side firewall and if I do what do I do with the two lines that run down by the thermostat. Its one line than it branches into two seperate lines. Just plug the one line? Not sure if that will help or not. I got the taboo directions but its still unclear to me. what does wgs, eps, and tvv mean also.
The canister on the passenger side under the battery can be taken out. You can also take out the FPS (fuel pressure solenoid) but it could cause hot start problems for you in the future. I am assuming you have a AFPR (adjustable fuel pressure regulator)? Anything you remove will need to be capped off or recirculated back to itself.
Look into relocating things if you want to clean up the engine bay. Things don't always need to be removed. You could just relocate them to an area that isn't quite as visible.
Oh and WGS is Wate Gate Solenoid. For more acronyms/abbreviations, check this out http://eatsleepdsm.proboards.com/index.cgi?board=miscellaneous&action=display&thread=58
I take it your state doesn't check emissions control during inspection? If they do, disabling your fuel vapor recovery system will fail inspection.
