vaccume lines help
pull a stick line andmeasure the diameter. it would take a good 10 feet to replace all of it i would say.
Remove emissions equipment...then you won't need any freakin vacuum line.
Otherwise, the nipples on the intake manifold and on the throttle body are 4mm. PCV / Brake Booster / VC Breather are 8mm. BOV line is 4mm. And yea....
