Drift_SM
- 772
- 5
- Jul 28, 2005
Titusville,
Florida
Im using a turbo 1g A/T fuel pressure regulator for my 1g fuel rail.
Solved. The 2g SFPR will not fit on a 1g rail. Unless the flange bolt holes are modified.
Solved. In most cases when the Stock FPR fails, it fails to "Keep up" with the flow. The system will run richer.
Solved: A Stock FPR will remain at a 1:1 ratio unless it is over run.
