FunnyGas
- 33
- 0
- Aug 7, 2005
Kamloops,
im looking for some answers on this...
i have an oldschool palm that i have been using for datalogging. it works fine, but my predicament is...
A. i dont have a serial connection on my laptop
B. both my computers run vista, and therefore i cannot hotsync
so all the data stays on the palm... which is a pain in the ass since the cradle isnt 100% anymore.. and wont hold palm it... i have to have it duct taped together...
so i have a USB - Serial converter with the drivers installed. it registers at COM port 4.
i can use other serial devices just fine with it. i swapped pin 2 and 3 on the logger cable i made for the car as per the wiring diagrams.
the TMO software allows me to connect (doesnt connect when car is off or not plugged in) but it always says "link down". i changed the baud rate to 1200. still the same result.
now when its connected (all 3 wires connected to the OBD port)
what im looking for is anyone who has sucessfully used a USB connection to datalog with (i have seen some posts that people claim to do it), how did you do it? what software did you use? what hardware did you use? did you make your own logger cable? what OS are you running? what are the settings for your serial-usb adapter?
if you are going to tell me it wont work, please refrain from posting unless you have a detailed explanation as to why it wont work...
