update to my engine problem
djuorna22
36
Mar 3, 2014
Marinette, Wisconsin
so knocking noise started and kind of came and went now at 2k rpm its easy to hear... first thought was rod or rod bearing. so I tried holding at rev where I could here the knock then pulled each plug wire off one at a time but knock never topped so does that mean it has to be something else? timing belt loose?something more top end? I don't really want to just start tearing it apart I'd like to have an idea where to start or if its even worth it.
You could always drain the oil and inspect it. Don't rule out a bearing just because the test's didn't indicate it.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
