turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
I got one tonight but i have higher goals than that wheel will flow (50mminducer) and i want to put a real 58 or 56mm wheel n it if i get it, is this possible
also the turbine housing is frozen on with one bolt stuck for it's life that i'm gonna hve to cut out to seperate the housing from the CHRA, is this turbine useless as far as housings go, I was gonna machine a T3 5 bolt housing to hold it, but i know i've heard nothing but bad in the holset thread about this turbo it seems
so, can i put the bigger 56 or 58mm 35 or 40 wheels in it?
edit: I shuldd add this isnt the typical small h1c, it's an 8 blade unit with NO WASTEGATE, what i found on a cummins forum is that it's from an older 12v motor and also used on tractors or something, it also has an 81.2x mm exducer and the weirdet blade structure i'veever seee, if anyone can help with this i'll be apreciative, i'm working on getting pics up
ok, it gets weirder and better...the inducer is like i said 50mm 8 blade, then with the secondary blades making it a 16 blade, but the major of the exducers is 3.2 inches or 81.23mm, the housing is non-MWE, it's i a twin scrol hot side that's HUGe and has no wastegate but does have a 3" v-band oulet
some one help me figure out what thisis capable of and if i want it or not (i have till tomorrow to decide really
the turbine is 12 blades but since i can't get it apart yet i only know the minor diameter of 2.47" or 62.79mm
Here's pics
Any idea what the total airflow capability of this turbo is????
Here's pics
Like i said i like the v-band compressor housing, and as soon as i machine a t3 5 bolt husing to accept the turbine wheel i'll be runningthis baby
