UICP for BlowThrough setup help
Crawl
325
Jan 8, 2005
portland, Maine
Ok I have the GM maf, the MAf translator. And I want to set up my car blow through> i already have intake pipe for the turbo to cone with no recirc or anything else on it.
I also already have a Dejon Tool UICP that im running with the normal setup. I was wondering if anyone sold a pipe to go from the uicp to the Throttle body with a spot to hook up the GM maf, or if i had to buy the entire damn piping with a new UICP from dejon tool? I coudlnt find anyone else who sells a blowthrough Upper IC piping other than Dejon Tool and they dont sell anything to add to the original UICP only a whole set.
Just use your current UICP and take a little off (2-3") of where the UICP meets the throttle body elbow part and use couplers.
well i have the dejon tool UICP that come up to whee the bov is then uses the stock rubberish uicp pipe to go from there to the TB elbow
Sorry about that. I was assuming you had a 1g (didn't look in you profile), and the 2G's are different. So you only have the one lower section of the UICP.
You could either just shell out a couple bux and purchase the upper half and then modify it, or just sell your lower section and purchase the blow thru setup. (I'd do #2)
hehe, i was afraid that was the answer, Are their any sites or other vendors that sell a blow through setup or is my only option the 200$ uicp set with the couplers.
