blowthrough venting
What size injectors do you recommend. This is my DD and my goal is 300hp to 350hp. Also i know that DSMlink is great, but is there another logger without the use of a laptop.
But you do need the larger injectors to compensate for the larger air flow, and obviously a logger so you can tune the MAFT.
Not really. You can run a MAFT set to 450s and emulate stock operation.
A logger is ALWAYS needed, however.
No. Brian (snowborder) is correct. The increase in airflow (if any) will be so low that the ecu will be able to compensate for it with the stock injectors. And you can leave the maft set for the stock settings.
Edit: Damn, Kris beat me to it.
I don't think anyone has made it clear yet that you could run bigger injectors though. The maf-t will allow you to tune the signal that it sends to your ecu allowing you to run larger injectors without running rich as long as you have a logger to figure out what is actually happening. It happens to be a relatively crappy way to tune on its own though since it wont help you gain any control over timing or offer any of the other features that would come with a more robust tuning system.
