blowthrough set up?
koberm
Aug 3, 2005
norfolk, Virginia
I just got the blowthrough setup w/gm maf and maft. Does that mean I have to get a new intake pipe since that eliminates the stock mas? or is there away I can make that setup work w/out getting a new pipe? Ive searched all over this place cant find anything.
I also got walbro 255, 550 injectors, apex-i afc on the way to compliment the set up.
Cleanest way to handle this problem is with one of Dejon Tool's no-MAS intake pipes..
www.dejonpowerhouse.com
koberm said:
has anyone ever left both on there(stock mas and gm maf maft)?
The stock mas would be a airflow restriction. I had to use the stock mas for a few weeks before I got the FP intake and the air filter. It would be best if you buy an aftermarket pipe that eliminates the mas or do the DIY pipe.
do you have the upper intercooler pipe to mount it, even if its a gm maf, its not in blow through set up unless its on the upper intercooler pipe between the bov and the throttle body
