GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
So I installed a fmic and was tempted by the knockoff greddy that came with it. I am also going SPEED DENSITY, no maf (already installed).
I decided I wanted to vent my bov until I come up with a clean recirc path, (new intake, new bov location...) When i was test idling my car I could feel the bov blowing out air! I looked in there and saw the valve open at idle. I figured Im pulling too much vacuum and its opening up. (this was the greddy knockoff) I tightened the spring down, and it was all pretty much good. but still leaked a hair at idle. Then i gave up ant went to the faithful 1g bov with less than 30k on it. It was worse!!! It just let air flow out. And theres no adjusting it. My idle was around 1000 or lower ( i leave it set around 900). I thought if anything it would be sucking air in.
Does all metal fmic piping and a no maf 3" air intake make the car sound like its leaking under boost? It sounds like I rev the engine (under load in gear, turbo spools, then I hear a serious air rushing sound, then of course the blow off after I let off the gas.
I did a BLT, and my biggest "leaks" are at the 1g bov @ ~22psi and the mbc (I just screw it all the way in for tests it holds. The leakdown is very slow. Ill get bored watching my boost guage leak down to 5psi. it takes a pretty long time.
I had some guy do aluminum welds on some pipes. HE sucked. there are pinholes everywhere but they leak very slowley, and ill braze them or something later i dont think they are significant right now.
I dont plan on making over 22psi anytime soon. Do I need a new bov or am I just over reacting to the new sound of my whole intake/fmic setup?
Ill get a vid up if I can take a HQ sound clip.
