Twin scroll info help??
Jun3bug
55
Sep 7, 2009
Greensboro, North Carolina
I have everything inline for my twin scroll setup. my question is since I setup my ecmlink v3 SD I had to reverse the firing order. Will this effect the twin scroll setup in any way??
Change the firing order what that's new to me can you please elavorate?
The 2ga and 2gb Cam sensor signals are inverted from each other. So, When a 2gb owner uses DSMlink with the 2ga eprom ecu they have to swap the plug wires from 4123 to 2314 for the firing order to work correctly.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
