86gixxer
- 0
- Feb 14, 2010
Durant,
Iowa
I am new to DSMs (as most could tell
) and just picked up two from my cousin. Ones a gsx and ones a GS. I am swapping everything from the GSX over to the GS (with the exception if the AWD drivetrain) and using a VCE.
My question is, since this will be a DD for when I cant ride my bike, whats a good turbo size for it? I am dumping the blown 14b and want a little more power. I am adding a TBE and wires and plugs (bigger wires) and probably a FPR and larger pump. I am replacing all seals and elimintating balance shafts while the motor is out. I am also going to do timing components and belt also along with the water pump.
Give me some ideas and thanks ahead of time.
Also if I am missing or incorrect on any of the supporting mods let me know.
) and just picked up two from my cousin. Ones a gsx and ones a GS. I am swapping everything from the GSX over to the GS (with the exception if the AWD drivetrain) and using a VCE.My question is, since this will be a DD for when I cant ride my bike, whats a good turbo size for it? I am dumping the blown 14b and want a little more power. I am adding a TBE and wires and plugs (bigger wires) and probably a FPR and larger pump. I am replacing all seals and elimintating balance shafts while the motor is out. I am also going to do timing components and belt also along with the water pump.
