Turbo question - pounds per square inch
Deadly BlaZe
1,890
5
Oct 2, 2004
Alpharetta, Georgia
So let's say a turbo is boosting 10 psi, how do you determine how many square inches there are for every 10 lbs??
Becareful not mix up volume and surface area units or you will confuse people even more.
In³ or cubic inch units are used to indicate volume. 3D
In² or sqaure inch units are used to indicate surface area. 2D
Although pressure is expressed as pounds per square inch (surface area) the volume of a substance at X psi would still be represented by cubic units.
If you want a real world example, think of a standard scuba tank. The most common size contains 80 ft³ of air at atmospheric pressure, crammed into a container of about 0.5 ft³. The starting volume is 160x the tank volume. Boyles law says that at the same temperature, the pressure would be 160x greater in the tank. 160 x 15psi (atmospheric) is 2400psi.
My bad... I just figured that'd it be easier to grasp the concept using area instead of bringing in cubic measurements. I guess that would be misleading, my apologies.
Same concept, another example for my sake:
a scuba tank containing 60ft³ of air at atmospheric pressure has a volume of .5ft³. p2=p1V1/V2, or p2=[15psi(60ft³)]/.5ft³=1800psi.
How do you do the subscript and superscript on here?
Alt+0178, Alt+0179
I haven't figured out subscript yet.
Edit: got it. {SUB}and{/SUB}
You can also do {SUP}and{/SUP}
Replace the {} with <> but you can't see it when I type it that way.
...and yes. Your math is correct.
Alt+0178, Alt+0179
Thanks! :thumb:
