shadow001dsm
- 183
- 0
- Mar 26, 2009
las vegas,
Nevada
I have a 94 gs that had a turbo motor put in but they didnt bring the turbo with it when they did the swap they just bolted the stock gs stuff back on so i have the turbo pistons block and head, can that creat damaging problems to the motor without boost?
it wont hurt anything to run a turbo engine without a turbo, it'll probably just feel like a dog cause of the lower compression. who did the swap? please tell me it was not sun auto, cause this sounds right up theyre alley
yeah its slow i can walk a 1/4 faster than my car, its best is a 17.22, and no they left the stock gs ecm in there, and they put the gs injectors on it, they only thing the took for from the swap is the block and head everything else is off the old motor. and i went to the lamb one on saterday before midnoght meyham and didnt find anything but other fw n/a talons and one laser and two eclipses, but i heard the one in henderson had a 14b, and a 16g there i was gonna check that out, and thanks for the welcome my fellow vegas dsmer. you meet up any where out here, the sonic meet is lame and no one realy is in to it.
Only at Idle with a TURBO ECM would the AFR be acceptable. An NA ECM with Turbo injectors would run constantly rich, and then when pulling up to 0mhg of vaccuum it would give a lil more fuel adding to the already unburned petrol. A rich running car not only consumes too much fuel - Burning a hole in owners pocket it also kills HP, fouls plugs, fouls O2's, contributes to catalist failure (especially in OLD Cats!). So in fact it was wize of the installer to leave an NA ECM and install NA injectors! Yes it would run, but not as well as it should... MY 2 cents... Or actually he could spend more money and swap in a 2G MAF and intake pipe then perhaps the AFR's would be compliant!
Also regardless of "duty cycles" - Base/Vaccuum fuel pressure, fueling map in the ECM and Injector pintle size is what determins the fuel output at any given "duty cyle" @ any RPM (beside the other obvious reference signals from MAF,MAP,CTS,CPS,IAT,etc...). So infact a 440cc verse a 370cc, 240cc, etc ...at 40psi BFP @ 50% duty @ 900RPM @ 500mhp the 440 consumes and sprays more fuel!! The ECM is not witty enough to compensate for the larger flow of the Injector and the engine cannot cram any more air into the engine atmospherically so It'll always run RICH!
Perhaps at that rate the OP could invest in some Cummins or Powerstroke Badges and tell everyone the smokin tailpipe is from his new DIESEL engine swap!?
Duh.... SO now its even Slower and burns too much fuel, more than previously mentioned. That is if it where NA ECU with Turbo Injectors, hell the static compression alone makes it a slushbox, add FAT injectors and quick accellerating Ignition timing and you have a 1970's Pinto with a steam engine swap!
I need 50 posts to list some of my DSM goodness in the Marketplace, so I'm halfway there and wasteing post's on gibberish like this...
for me.
