Turbo install problem help???
rixcidia
280
Dec 5, 2007
Somewhere in BC,
Hey guys so I installed my turbo and forgot where these tubes connect to and in which order im running a greddy type-s bov and an after market chrome intake as well as my 16g turbo and the j pipe has a welded nipple on it aswell,l I posted a pic with the part in question and also a pic of my setup before i pulled it all off to install the turbo i also just bought ECM LInk and got the boost control selinoid which is the third pic and I'm not sure where or how to install this it has 3 nipples on it and two wires please help me out thanks,
Rix.
In your first picture I can see your shifter cables so I can tell the blue hose is your lower radiator hose. That being said, that vacuum solenoid should hook into your turbo and intake. I can't tell you which goes where right at this moment, but if no one else has supplied the info you need by the time I get home from work tonight, I'll post pictures of how it should be set up. This is also the location a lot of people hook in a DIY boost controller.
Scroll down to my last thread regarding vacuum hose. I think you and i had the same issue. Looks like waste gate solenoid hoses?
