turbo coolant lines...
dsmxfan
58
Feb 7, 2011
kettering, Ohio
im putting a 14b in my 99 eclipse gsx. the turbo on it now has no coolant lines to it, so im going to have to buy new ones. should i get the lines for the 2g?
EXTREME PSI : Your #1 Source for In Stock Performance Parts
or the ones for a 1g, since im putting in a 14b?
from what i can tell he just plugged the holes for the old line, is there anything else i might need? like extra hose? or just the lines. :confused:
You want the 1g lines, as you can see at the top it says 14b/16g/20g. I would just get the lines, bolts, and crush washers. Rubber fuel lines and screw clamps are never a bad idea to have around, just make sure you get hose that has the same inside diameter as the water lines outside diamater so the hose can slip over the line.
