turbo coolant line
lotta hp
Banned Member
41
Sep 28, 2012
A, Georgia
Since my water pipe has no coolant ports can I use the thermostat housing for both the feed and return?
I seriously doubt the coolant would actually flow.
Taking a basic look at it, what causes flow? Pressure differentials. If the feed and return are from the same sink at the same pressure, there is no flow.
Im going to change my turbo coolant line to a stainless steel with -6an fitting or should I do -8an?
I just wanted to make sure I have the correct sizes for a 1g
for the water pipe m16x1.50mm
for the turbo: m14x1.50
-6 is good enough. the entrances to the SS line from the pipe and the entrances(inlet circumference) to the turbo are almost equal to an6, any bigger wont make improvement, IMHO maybe any bigger may create some air pockets but I dont think it would really happen and if it did I dont think a pocket would last in the line considering the temps.
Those are the correct sizes (unless you've got a lame*ss 13G).
I don't think it will matter, however, I have use 8AN's with out a problem and there will be no problem at all if you use ether 6 or 8, The lines are not really to cool down the turbo while running, the oil is the one that cools the turbo and the water is an extra cooler, the water is there for the turbo to be cool enough when you turn off the turbo.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
