2G Tuning Help with DSMLink v3
Andranik
109
Nov 5, 2010
Brockton, Massachusetts
Can someone go over my log and tell me what I'm doing wrong please for some reason the car just wont run right and I'm getting so aggravated with it. Here is the log with it running
Your MAF Comp settings are WAY out of whack. I'd start by zeroing them out. There's no way a stock 2g MAS needs that much correction.
Everything else seems to be acting normal. I would do the above, then watch this video and mimic what is shown to get your fuel trims (CombinedFT) and AirFlowPerRev in check.
http://www.ecmtuning.com/demos/fueltrim.html
It also looks like you're running an older firmware. I would suggest upgrading it.
ECMTuning, Inc.
Once that's all done, post up another idle log please (at operating temp, obviously).
I just pulled the plugs and i found out that im only running on cycliders 1 and 4 ... 2 and 3 arent firing up any help with that ??
its a fresh built motor its a 6 bold in a 2g ... i checked all the wires at least 15 times
so uncheck the misfire thing in dsmlink and that should fix it ? i will try that in like half hour will post the results
that didnt help my problem :(
hey guys i just found out that my car is running on cylinders 1 and 4 but no spark at 2 and 3 ... i check the coil replaced the coil plugs wire ... what else could the problem be ?? please help with any info
I also changed the cas idk where else to look :(
