ECMlink Trouble getting consistent readings
tina the talon
Oct 23, 2015
rio rancho, New Mexico
I am having trouble getting my afr to stay consistent at idle. I can set the afr at idle take short easy drive and the vehicle will start idling very lean ( 18:1 or more) vehicle is acting like it may have a vacuum leak. I smoke tested the system had a few leaks and were repaired. retested and had a minor leak that wasn’t too bad from the throttle shaft Body. Anything else I could check or any ideas. I am using the stock maf and a aem wide band to Monitor
