Getting Wierd readings from logger.
Spooling99
651
17
Sep 21, 2005
Marshalltown, Iowa
Ok so I just re installed my logger and everything was good the first time I had it in. Well I was driving around yesterday and was logging RPM, Timing, Knock, and O2 sensor. At some point my knock sensor was reading 211 counts of knock :confused: , The timing some how got up to 245, and my O2 sensor was reading 4.05 WTF. I checked to see if it was in 3KGT mode and it wasn't. Any suggestions. Also my mods are up to date. Im using the Pocket logger with a Palm IIIc. Thanks in advance.
-Adam
I went for a ride earlier today and everything looked and seemed ok on the logger. Also last night I was getting 1 to 2 counts of knock so I decided to log my injector D/C and it was at like 123 wot and my TPS was at 96 WOT. Think this is a communication problem as well? Im only running 12psi why would my inj D/C be that high with no knock?
-Adam
Thanks for the help. I'll be sure to do a boost leak test asap.
I run stock boost and see about 95% INJD near 7k rpm. I've got some boost leaks to fix as well though. Man, I can't wait until my car is running as good as it did from the factory...I've only had it a year now and am still fixing things. haha.
