o2 voltage readings from my logger
soul
68
Sep 16, 2002
Macon, Georgia
I haven't figured out how to get the info off my logger. I can't go wot. The car just acts like its not even there. My o2 showed 0.00 anytime i press the throttle. WTF am I doing wrong? What does 0.00 mean?
Took a second spin and zero'd my afc out...the car still runs like shit but it runs better than when I lean it out any. My 02 voltage still shows 0.00 except at idle. I actually built some boost before bogging out with the afc zero'd.
I'm just lost :cry:
fuel mods:
safc2
680cc injectors
255 walbro
its reads at idle....does that change anything?
What are you using to log with? You still really need to get a fuel pressure gauge to check that out because it sounds like you just aren't getting enough fuel pressure from both of the posts you've made. I won't say the ground strap does or does not do anything, but mine is not hooked up right now and I have no problems with O2 volts.
