Transmission problems...
StanleyDSM
248
6
Jun 30, 2015
Cherryville, North Carolina
So I noticed a few days ago my 5 speed f5m31 transmission was grinding a bit in first and second. I thought I was low on fluid so I put some more in. I help it for a day and then it started back this morning on my way to work. But now it was also third. So I came home and started taking it apart and I found this.... Only my luck..
No i just sprayed them down and cleaned them so I could bringem inside later. I'm think either get new synchros and get my welder to fix the two holes or to do an awd swap.
I think you actually got lucky.
I would try to just source another good used trans. You could easily spend more money on that than a used one in good shape. Then try to just sell the guts as is to make some money back.
Just curious, do you have the stock damper crank pulley or an aftermarket one?
If you post the old trans on the classifieds, see what kind of response you get.
I was thinking about excessive vibration, harmonics that may have caused the bolt to come loose.
