Automatic transmission problems
Jungy
97
Nov 2, 2006
Saint Cloud, Minnesota
I'm posting this up for my friend (tehehodi). So his Auto 2g recently started having problems with the transmission, the car drives forward when in neutral, it roll back a couple inches and then drops out of reverse, and has some bad shifting problems in drive. We tried checking the fluid today and its clean and not burnt at all but we cannot get a good consistent reading on the dip stick. We followed the AT fluid checking procedure running through the gears and then checking it in neutral, maybe the problem is because the dipstick tube had to be moved for the vrsf front mount? I'm attaching an in car driving vid to see if any of you AT guys can help out.
http://youtu.be/ok7IT1X0ZVM
