Transmission Issue
FalpenHost
3
Jun 10, 2022
Wellford, South Carolina
*Sorry if this is in the wrong section*
About 3-4 days ago, I purchased a 1997 Spyder GS 2.4l. It drove fine, no transmission issue while driving. Was on the interstate 30 minutes, going about 55-60. After about 30-35 minutes the car shifted into Neutral and would only rev up. Thought it was over heating (heat hand doesn't work) so I sit with it about 30 minutes to cool down. Got back in it. It drove another 5 minutes, and same thing. Shifted into N and only revs up.
After this time, the car wouldn't go into any gears. So I had it towed to my house. The tow bed was covered in what I thought was transmission fluid. Dark red color.
I only know a few things about this car. And one was that the Passenger CV axle kept sliding out. So I figured that might be my issue. So I got that, and put it in. No change.
Checking the Trans fluid at running temp, and it was full. Checked the power steering, full. Brake fluid is full. Oil level is full. Everything that could be what I saw on the bed of the tow truck was full. So I have no idea what the fluid could be.
When shifting, nothing changes. The idle stays the exact same. I thought it could be a broken shifter line. But the shifter is working on both sides. The only way I can tell it's in gear is because I can Push it in gear, and I can't push it in Park. So I know it's shifting, just won't move.
Any advice on what to do?
when you put in the new cv axle was it indeed unseated? If so you had to have lost fluid.
When the car broke down on the side of the road, I did see a ton of fluid on the ground and like I said on the tow truck. But when I pulled the CV axle out, no transmission fluid came out. But I did add 3 qts of trans fluid to it before I had it picked up by the tow truck.
It is worth mentioning that the old CV axle had no lock ring on it. And the lock ring was not in the shaft hole on the transmission
You found your original problem. Driving with low transmission fluid probably burned the clutch packs out. Sorry to say it, but if the car won’t move with the correct fill level (car idling in Neutral — not Park), then it’s rebuild time.
I appreciate it. Figured that would be the problem. Gonna call around to get it rebuilt tomorrow.
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
