2G 99 Eclipse Transmission issues
darkraven18
Sep 1, 2012
zebulon, North Carolina
Alright so first off I got into a car accident that resulted in the front of my car getting smashed in, but please keep in mind that all of the major things like the motor itself and transmission were not impacted what so ever.. so after replacing the support bar, radiator and what not the car was ready to be tested to see how it would act and that's when I ran into a problem with the car not shifting properly. When the impact happened I was thrown forward and in that process the gear was forced out of drive all the way up to park since I drive with my hand resting on the shifter, then after that the transmission locked itself and the guy who needed to get my car out of the way and off the road forced it out of the gear it locked down in.
I've got an automatic transmission and whenever I try putting the car in drive it seems to be fine but overdrive will not kick in, when putting the car in reverse it does nothing unless its put slightly above where reverse is closer to being in park for the gear to shift into reverse.. shifting into 2nd and lower does nothing what so ever. The only time I did notice that Overdrive will actually kick in is when the car is sitting in park, but any other gear and it won't kick in. I haven't heard any odd sounds either like knocking and the sort. just the same typical sounds it's supposed to make if that makes any sense.
Any ideas as what could be wrong and if this is an easy fix or complicated and expensive?
sorry in advance if I'm not explaining this very well but I am new at this and I know nothing about transmissions.
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
