420A Transmission issues
me2151
83
8
Mar 17, 2016
Jacksonville, Florida
I have a 95 eclipse GS with a "4" speed transmission. I say 4 speed because 5th gear doesnt do anything.
The issue is when driving 1-2-3-4 all work perfectly and even reverse engages. 5th gear feels like it engages but it acts like its still in neutral. The shifter is in the 5th position but no drivability. Now if I,while driving, try to force the shifter beyond the standard position I can feel 5th gear popping on the stick. My question is. Is this a gearset issue or a syncro issue? This is a 420a motor, what 5 speed transmissions are swappable or would it be cheaper just to fix this one if its just a a syncro. It is not a linkage issue I believe as its only that one gear.
Thanks for your help!
i havent had a gs trans apart, but you might pop the end case/cap off and check if the fifth gear retainer nut has backed off. this is all depending on if it is similar in build to other 5 spd FWD transmissions out there.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
