transmission cooling hoses
sk842018
Mar 4, 2012
Mitchell, Indiana
98 eclipse rs. 2.0 dohc non Turbo. Automatic. Car was wrecked and front end rebuild and a friend done work. He said he doesn't know for sure if.the cooling hoses coming from transmission are connected correctly to radiator. There's 2 hoses coming from tyranny to radiator. Does anyone know which one connects where on radiator or a diagram of I? The tyranny is in limp mode so I'm trying to diagnose any possible reasons? Thanks
I wasn't the one that took old out not put new one in,he must.of.not.paid.attention either. You day its.the tcu? I pulled it out.took apart it was.gel filled but looked good didn't see any Burns nor smell. It ran and shifted beautifully until wreck. Took tranny shoo pulled.2 codes p0765 shift.sylonoid D and p0700 transmission control malfunction(MIl) request. They tried.put.back I'm relearn mode but.didn't get.out of limp mode
Wrote on reciept possible wireing problems, or.tranny. since it shifted great till wreck they said the transmission most likely isn't problem. The srs light is on too. The only time I can get it.to try.and shift and.than right.back into limp mode.is unhook the srs comp under.arm rest and hook it.back up,start.car and.try.and.take.off.real fast. If try this with out unhooking the srs module it will not attempt to shift even f I take off quick as before. One mentioned could be wireing problem I've checked most and see no damage. Could the tcu go out.just cause or dame time as wreck? Thanks for.help. Really.need to get this taking care of wife's 7 mnth pregnant and need reliable.car that can go above 30/35 MPH.
