Cooling problem
Str8_Crazy
111
Nov 14, 2011
Rifle, Colorado
Just recently my fan stopped working but my gauge seems like it's working fine. It started overheating the other day and that's when I noticed it wasn't turning on. I have been doing research and I see that there is no fan switch just a coolant temp sensor. Could the sensor be bad to where it won't turn on the fans but read the write temperature?
Check the one at the bottom of the radiator. There are three sensors on the T-stat housing - one for the gauge that you see, one for the ecu, and one relating to the AC. I think the one on the radiator affects the fans.
Also when the AC is <on> both fans should run.
