1G Transfer gear Bearing removal ideas???
SasaniFab
2,432
788
Dec 1, 2013
Mexico, Connecticut
Ok guys all of my parts are in, im at the point now were im getting to install these transfer gears. The only issue im having is this gear has a very deep section and you cant get a bearing puller in. I don't think you can buy these bearing anymore. Unless one of you guys cross referenced the bearing. I think im going to throw the gear on a Bridgeport and mill out a channel from the inside and release it that way.
Darn I'd offer to buy one off ya, but I just put an order in for a new bearing from TMZ. Did you re-use the roller bearings on the drive gear?
Yes , i couldnt find that damn bearing anywhere. Your referring to the larger bearing yah? I couldnt find the damn thing anywere so i reused it. You couldnt find it yah?
Yup, Unfortunately I was unable to source those also. At least those bearings look easy enough to remove like you did. Just curious, since I have not pulled my stock gears yet, are those two larger bearings the same size?
The are the same size but are different. One bearing has a groove in its outer face.
