transfer case seals
more1Gpleez
Jan 9, 2008
Central, South Carolina
does anyone know what the oem or felpro part numbers are for the input and output seals on the transfer case? i have it off ### i pulled the oil pan off to pull the rods/pistons out and im picky bout replacin seals when i work on anything. the motor has been rebuilt recently so the water pump and other seals look good...but i'll take a closer look at them when i clean the block up *block/trans still in car*.
Output seal/Rear - MD701430, superseded by MR983368 (use this one)
Input seal - I believe is MD723202; the one on the transfer case that the shaft from the transmission goes in.
By looking at CAPS, I believe these are the numbers you need.
MD701430 - output
MD723202 - input
Looks like I got beat to it, gosh I take forever to look up part numbers.
good lookin out guys. so those are the mitsu numbers......got the felpro numbers by chance? i work at autozone and the discount is lovely at times. LOL
I know its a year old but i thought it might help to let people know that the NAPA part # for the rear transfer case seal AH1895E they had to order it but it was only $15
