1G Trans won't go into top gears
jdmtrav
Jun 13, 2007
Napoleon, Ohio
Ok, I just got my transmission back after a Shep Stage 3 molestation. I have everything all bolted back up, new T/O Bearing, and refilled with fluid. All the shifter cables are hooked back up, but now it will only go into the bottom gears (2nd,4th,R). I cannot get it into the other gears and it feels as if the shifter itself is sitting really low(towards the rear of the car in the console). I am thinking that the shifter may need adjusting but I'm not 100% sure. Has anyone else had this problem? Any advise would be helpful. Thanks.
BTW car is a 1990 AWD with a 92 Trans swap.
It won't go into top gears because you have a '92 trans. 90's shifters differ from '91-'94 shifters. Check this out
If you put a 91-up tranny into a 90 car, you'll need to use the 90 mounting bracket, or the tranny will only go into 3/4/5/R, 1/2 won't be accessible. Conversely, if you use a 90 tranny in a 91-94 TEL or GVR4 without swapping the brackets, 1/2/3/4 will work, but you won't be able to access 5/R.
Did your car originally have the same transmission or is it different?
Car is a 90. It had the 90 trans but everything was swapped over to 92, trans, t-case, and shifter wise. It worked fine before I tore it out for the rebuild. Hmmm
