2G Won't go into gear!
Popularman
Mar 23, 2012
Crookston, Minnesota
I'm new to dsm, I've recently parted out my 1g Talon TSI and bought my new 96 TSI AWD. I've done a few mods internally and externally. Here's my new problem. Recently I pulled my car out of storage threw fresh gas in and seafoam to freshen up everything. I even changed my slave cylinder and just today my clutch. I went through my car looking for leaks and can't find nothing and bled my clutch multiple times. The slave is moving fine and she still won't go into gear. She just started doing this recently one day after a long road trip picking up some parts, any ways everything is fine besides she won't go into gear. This is really frustrating and I just want to drive, all I ask from everybody is some advice on what the problem might be, I just want this to be fixed before I got to Brainerd in June, thanks for any feed back .:thumb:
Is the bearing in the clutch peddle good? There is a bearing inside it that wears out from time to time. And from my readings and previous experiences, it will not allow the master cylinder to be depressed all the way, and will not allow you to get into gear properly.
Sent from my T-Mobile G2 using Tapatalk
We just replaced the master and slave on my GSX and the next day my car wouldn't go into gear. We finally found that the line was leaking brake fluid and we had to re flare it.
Check your fluid reservoir and see if it is empty. Right where the line connects is where it was leaking. Now it works like a charm.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
