tranny fluid?
fordmanjoe76
Mar 21, 2008
Long Bottom, Ohio
just wondering if there is any tranny fluid at autozone that i can use instead of going to dealer?
my autozone told me that i had to use dealership fluid, but i knew that you guys could tell me what auto. tranny fluid to use. thanks again
I only lost about 1-2 quarts( axle change) will it be alright to top off with synchromesh or should drain the pan and go from there?
If this is for an Automatic, buy the ATF+4 (Calls for ATF+3 but it's been superceded and I don't think you can even buy the +3 anymore). If they want to argue, it even says on the back of the bottle that it is compatible with Diamond +3.
For a 5-spd, use the suggestions above.
Wiz
Use a synthetic like Amsoil and add eight ounces of Lubegard black.
Search for posts by Transdude (John from IPT) for more good information on maintaining the DSM A/T
