Tranny Fluid
garysever
36
Jul 14, 2003
I have a quick question about different tranny fluids. Right now I have stock fluid in it, and i live in minnesota so its damn cold. When i start the car the clutch takes a while before it comes back and the shifter is hard to move. Im assuming its cuz the fluid is cold. So then, my question is if there is a tranny fluid made for cold weather. I plan on putting BG synchroshift once it gets warm out again. but if i can find one that will work for the rest of the winter that would be awesome. thanks in advance.
-Gary
The usual fluids -Redline, B&M, BG, and Synchromesh are all considerably less-viscous than the stock grease. Now then, does that mean they'd warm up more quickly or more slowly than stock?
I think either way, you're fairly well stuck with slow shifting for those first four miles or so.
Redline-MTL. It works better than most synthetic tranny fluids in cold climates. MT-90 works great for me in the 10 degree mornings here in Kansas. If it is not much colder than that, use a mixture of the two, if it is very cold use pure MTL. Just my opinion.
Dan
