GSXeclipsePSI
- 563
- 8
- Jul 7, 2003
New Port Richey,
Florida
Hey my 1st Engine Build. I have a 6bolt block in a 2g.
I melted a piston due to a injector short. I'm looking to do a stock build with a few bolt-ons.
Block and head are on there way to being at machine shop getting cleaned and cylinder honed due to damage. Is there anything I need to tell him for the parts I'm using. I'm guess I need .020 over pistons.
Need help and explanation
I need some info/feedback on this rebuild kit from Topline
TOPLINE Eclipse Rebuild Kit 4G63 Turbo Pistons 1G 90-92 on eBay.ca (item 190306962036 end time 09-Aug-09 14:43:15 EDT)
*Any parts you wouldn't use from this kit and parts you recommend
I am also looking to get the BSE Kit.
New Timing kit
I have new water pump already and I am rebuilding my head with 272's all other mods are listed in my profile.
I am also getting a wideband and AFPR.
I ran 25psi before and I have ARP head studs. Can I reuse the head studs? What do I need to do to use the old ones.
Piston rings, how do I put them on correctly, if I buy the kit do I need to file them.
ALSO I know people ask this alot but is 30psi too much to ask for out of this build?
New Timing kit
