Timing tensioner
Learn to use the search button, and buy a chiltons or haynes manual. Retiming your belt is an easy but tedious process that is well documented on here. All you have to do is put the tensioner in a vice and put an allen key into the slot. Bolt it back on, retime the engine, and pull the key to tension the belt.
