1G Timing dot not showing up under timing light..
Vegas Smith
5,193
3,157
Dec 2, 2002
Houston, Texas
Hello, I'm trying to set my timing to 5 degrees and I hooked up the timing light only to notice that the white timing dot was jumping around. I realized I didn't ground the connector on the firewall so I went ahead and did that. Afterwards, I wasn't able to locate the timing dot anymore. I messed around with the CAS a little but I still could't locate it any more. Ideas? Thanks.
You need to do that ^
Your CAS is reading 180 degrees out, now.
Well I went and reversed the order of the CAS and I'm still getting somewhat the same problem. The dot is floating around but not quite as mush. I wonder if maybe the firewall ground is not make great contact with the sensor.
