1G Timing belt tension
Dsmanthony
Feb 23, 2018
Knoxville, Tennessee
So I recently changed my timing belt and everything is fine to an extent, Im pretty sure my timing belt is a little too tight because there are some odd marks in between the teeth of the belt on the top layer of the belt but I don't hear any whining from it being too tight. A 5/32 drill bit just barely doesn't fit and I was wondering if I could just back off the tensioner pulley slightly instead of compressing the auto tensioner and putting the grenade pin back in and starting from there. Also if I can just adjust the tensioner pulley slightly is there a specific position the pin holes on the pulley supposed to sit? Any advice would be greatly appreciated.
From my understanding if you can easily insert the grenade pin into the tensioner after rotating & waiting your tension is correct. If you can not insert the grenade pin then your tension is incorrect. Can you re-insert the grenade pin? If not your t-belt tension needs adjusting.
The tension procedure is objective and has been always. It's in the factory service manual. Vfaq.com has a complete but dated writeup. On the tensioner the pin position doesn't matter
There is no correct position. There IS a correct torque and a correct measurement of the hydraulic tensioner.
The words " I think" do not fit here. You either know it's right or you know it's wrong.
That tensioner is pretty strong so trying to back up the tensioner pulley will let the tensioner open up all they way. Use the long screw to press the tensioner down and insert the pin. Then you can loosen up the tension on the pulley and start again.
Everyone has their own way of doing a timing belt job but you can't go wrong with following the vfaq steps.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
