2G Timing Belt Question
Russeilson3
Apr 6, 2014
Sandpoint, Idaho
So I recently bough a 1999 Mitsubishi Eclipse GSX. I'm wondering every how many miles it needs a timing belt replaced? It was last done at 89,000 and it has 154,000 on it. Also where would I post questions on how to increase my gas mileage and horsepower? I have a K&N cold air intake on it already, the owner said he put a catalytic converter on it, not sure if that's stock or not? If I could get some answers that'd be great!
Timing belt is done around 60,000 miles but since you just bout it Id recommend doing it and water pump just to be save. Never know if previous owner actually changed it or used oem parts. Just better do getting it done along with all the other fluids being changed and checking everything over. Maintenance comes first before doing anything else
If ever in doubt change it and all timing components, a valve job isnt cheap especially if you have nice valves, wanna keep them straight.
Yes same as above, Timing Belt around every 60-80K(Max) and change Balance Shaft Belt, and if not already replaced maybe a water pump while your in that area and get a new mechanical tensioner pulley(Hydraulic tensioner only if needed or high miles) as well. Their is also some High End timing belts too that are stronger.
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
