Timing belt moving of the gears
Boostdclips99
306
Mar 19, 2006
Roanoke, Virginia
I finished up my timing belt change and have noticed the timing belt moving to the outside of the cam gears. I changed the tensioner and tensioner pulley during the install but not the idler pulley.
Well I took it all back apart and noticed there is some slack on the tensioner arm in and out. I know it should pivot but how much slack should you be able to move from the block? I tried to remove the arm but the bolt is very snug (thinking it may break) so I would rather not have that headache. What should I try next?
Replace this - no play is allowed. This is what's causing the belt to travel to the outside of the cam sprockets..Things aren't square.
This should have been replaces as well. When doing a belt, all components are recommended to be replaced-including the WP ...
good luck - DSM
    • george bromwell
    • pma1123
    • Sdcryan1
