Timing Belt Change (What size bolts)
DearestNameless
308
Jan 16, 2010
Linton, Indiana
I started doing a timing job about a year ago and broke the balance belt pulley bolt off in the block. Since then I've grown the balls to attempt to remove it but I now have no idea what bolts go where and what size bolt I need to replace the one I broke. Is there a diagram or list of what size bolts go where. Thanks in advance tuners.
FML, right? LOL
The Balance Belt idler, and no I have not. I don't plan on it due to funds and the overall task. Unless it would be a much better choice? It isn't a DD but I still want it nice.
Remove the balance shaft sence your already at that point and don't look back.One thing less to worry about.:thumb:
Isn't that a 8mm with 1.5mm threads - the BB idler pulley bolt stud size and thread pitch itself?
The thread pitch is a 1.25 . As for getting the bolt out, i would pull the oil pump and back it out with a chisel. IT should just turn right out if the threads snapped from over tightening.
