TrystanGST
- 573
- 1
- Jul 29, 2004
Chicago,
Illinois
So a few thousand miles ago, I replaced the timing belt and water pump on my GSX. Last week, the new timing belt broke. I pushed the car back to the garage, and have torn down the motor. All four pistons show signs of impact, and at east four of the valves are bent.
Piston 4:
Piston 3:
Piston 2:
Piston 1:
Valves 4:
Valves 3:
Valves 2:
Valves 1:
So I turn to you guys. Do the pistons need replaced?
The car has no mods, and at this point I just want to get it running. However, I don't want to have to open it up again, so if there is anything that should be replaced now's the time.
I'm not planning on making this a 600hp awd beast, although the ability to eventually push 400 would be nice, if I choose to go that route.
I have a 6 bolt block and crank sitting around from a previous car.
Crank:
Cyl 4:
Cyl 3:
Cyl 2:
Cyl 1:
As you can see, the crank and block would need some machine work. Is it worth swapping? I don't have much else from that block, besides the oil filter assembly and the caps for the crank.
Thanks for any info/advice.
Piston 4:
Piston 3:
Piston 2:
Piston 1:
Valves 4:
Valves 3:
Valves 2:
Valves 1:
Crank:
Cyl 4:
Cyl 3:
Cyl 2:
Cyl 1:
Also maybe check the crank bearings for any damage as well as this would be the best time to replace them if needed.
Hopefully his doesn't break
