Water Pump ate the block?
BoostedBeaver
Moderator
957
295
Aug 15, 2009
Augusta, Georgia
I was going to reassemble the block when I found this. Right around where the water pump spins you see some wear. I did not notice this before I had It cleaned. Is it ok to continue to run this block?
What would cause this?
The water pump that came off of the block has no play what-so-ever and has no scuffing on the fins to suggest contact. Can anyone explain this and tell me if it is ok to run before I have it bored over?
For some reason I can not get the photos to work so I have provided a link. The first Six photos show the issue listed above. The last photo has a quick drawing to show the part in question. The red is the damage and the blue is the travel pattern of the fins. All help is Greatly appreciated.
Engine 4G63 pictures by robertbaxley03 - Photobucket
I wouldn't worry about it. It doesn't seem to be very deep. It probably was there from a previous water pump if this one didn't have any play. Is this a motor that was previously in your car or one that you purchased to swap in?
I believe he was referring to the wear on the block from the water pump.
Yes the damage that I speak of is from the waterpump on the block. This was a motor that was in the car and ran fine. Had no cooling issues at all. It is not very deep into the block I just did not know if this would cause a cooling issue or if someone else had this issue before. In one of the pics the damage is circled in red color.
If it was going to cause a problem, it would have shown up when it was in the car before.
Well it seems as though no one has any negative comments on the subject and the advice I have gotten is along the same lines I was thinking. Thanks for the advice and on with the build I go.
